6x4 Gas Gator Won't Stay Charged???
   / 6x4 Gas Gator Won't Stay Charged??? #1
BFET529
Fowlerville, Michigan
Kubota L2550, Belarus 250AS, John Deere 6X4 Gator
I have a 6x4 gas John Deere Gator that won't stay charged. If I charge the battery, it starts and seems fine. If I charge it to full, and leave it sit, after a few days or a week, the battery will be dead again. This leads me to believe something on the machine is drawing power from the battery. It only has the electronic lift for the box, and headlights that turn on and off (both operated by a simple toggle switch). Now the catch... If I charge it full, it always starts and runs fine, for about a half hour or so (give or take) and then dies... This leads me to believe it is the stator? What I don't understand is why, if I charge it to a full battery, woud the battery be dead after a week if is never started or run? Could the stator be drawing if it is in fact bad? I would like to think it is the stator because it will charge and run fine, and then die, as if the battery is not being charged as the machine is being run?? Anyone have any ideas? I am hoping this is a quick fix so I can use the machine again! Sick of getting stranded wherever it decides to die on me!
Also, from my reading on similar problems, a lot of people seem to have a problem with a bad voltage regulator? Does this have anything to do with the type of problem I am having?
Thanks for all the help!
   / 6x4 Gas Gator Won't Stay Charged??? #2
Do a load test on the battery. I think it probably has a bad cell or two.
Thanks guys,
I have checked the voltage while running and it reads above 14, and not running, reads at about 12.5. The battery was replaced a couple months ago, when I first got the gator because the battery was bad. The previous owner said that he had this problem, so I am thinking that there is something not working properly, causing the battery to take a crap. Any other ideas?
   / 6x4 Gas Gator Won't Stay Charged??? #4
Thanks guys,
I would disconnect one terminal from the battery and connect it through an ammeter, then see what the draw is with the Gator shut off. I would then start pulling fuses or disconnecting things until I found what was causing the draw.
Aaron Z
   / 6x4 Gas Gator Won't Stay Charged??? #5
I would do what Aaron said. Let us now how much of a drain you have with the key off.
   / 6x4 Gas Gator Won't Stay Charged??? #6
Thanks guys,
I don't know if your gator is shunt or field regulated. Either way, it could be the regulator. I assume it is shunt regulator, but I could be wrong. I don't really have enough info.
Field regulators sometimes fail when they get hot. When they cool down, they work again. The way to check for this is to get it good and hot and make that voltmeter check again. If you don't get that same 14 volt reading, it is an indicator that the regulator is intermittent. However it would not explain the battery going dead after being charged then sitting awhile.
Shunt regulators work by passing excess alternator output through a resistance to ground. It is conceivable that a shunt regulator could fail by "sticking" on. That would explain the dead battery after the engine has been shut off for some time. It would not explain the failure when the engine is actually running, unless the regulator is intermittent between two different failure modes, very unlikely but remotely possible.
It is possible you are dealing with multiple electrical problems, including a new bad battery. A parasitic drain, which is what Aaron is suggesting you check for, would not explain all your problems. Combined with a second problem, it could help cause your symptoms. It is definitely something that should be checked.
I don't know how knowledgeable you are regarding DC electrical testing. If you are not familiar with using ammeters, please read up on the basics before trying that. Unlike a voltmeter, it is real easy to smoke an ammeter by passing too much current through it.
Misfire
Thanks for all the help guys...
So I went out and messed with it for a few, and apparently my memory wasn't working so well when I posted last, so please disregard on the 14+ volts. Using the digital read out on my battery charger, the battery reads 12.5 volts not running, with the key off. When re-tested while running, it read 12.1. This 12.1 remained constant even while running the engine at high rpms. I only tested for about 2 minutes while running, but it still never changed from 12.1, regardless of whether at idle or high rpm. Once the engine was off and not running, it read 12.4??? Since I can't seem to find my multimeter, I am going to pick one up today while I am out to test for a parasitic drain, and will report back. For now though, with the proper numbers given, does this make any more sense?
   / 6x4 Gas Gator Won't Stay Charged??? #8
If you are only reading 12.1 while running it is not charging. Check you fuses first.
   / 6x4 Gas Gator Won't Stay Charged??? #9
Yep, you definitely have a charging problem. BTW, getting a slightly higher reading after you shutdown is normal. Batteries tend to bounce back slightly when the load is removed.
Don't worry about parasitic drain until you get the charging problem resolved. That is probably all that is wrong. The 14+ volt report threw everyone's diagnosis off.
Understandably so on throwing the diagnosis off! So I need to look at a new stator and hopefully that will fix my problem. Could the bad stator be what is drawing while the machine is off? And lastly, could the voltage regulator still be bad and causing these issues? Could the charging system actually be working properly, but the regulator not allowing the charge to make it to the battery?
Did I mention that I hate electric problems!?
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
