6V tractor with 12V coil
   / 6V tractor with 12V coil #1
DanB53
Bronze Member
Soo, Ontario
McCormick W4
I just bought a McCormick-Deereing W4 that has 6v generator, wiring, voltage regulator and battery but a 12v coil. I haven't got it running it yet but before I do should I change coil to a 6v or does it matter?
   / 6V tractor with 12V coil #2
Why don't you put a resistor in there. I think that's how Larrys Wd Allis was hooked up. A resistor like the one on my hit and miss engine is what he used. Running with the 12 volt coil will probably have to much resistance and make the engine have a weak spark.
Thanks Mike I think I'll just buy a 6v coil and make it right.
   / 6V tractor with 12V coil #4
A resistor would make the spark weaker. On 12 volts you need a resistor with a 12 volt coil. On 6 volts I dont think (not absolutely sure) you do. I think I would run it. It might be hard to start when cold. On 12 volts systems they used to bypass the resistor on starting.
   / 6V tractor with 12V coil #5
Adding resistance would be counter intuitive. 12V coils actually run on about 6 volts so you are about right. The ballast resistor / resistor wire in series with the coil reduces the voltage. When starting, the battery voltage is low due to the heavy current draw, so the ballast / resistor wire is bypassed during starting to supply the coil with the full battery voltage. If it starts ok, don't worry about it. If the spark is weak and there is a ballast or resistor wire, replacing it with a piece of wire will help.
   / 6V tractor with 12V coil #6
man what an electrical mess this thread is.. but it's partly to blam on manufacturers labeling 6v coils as 12v, then in small print saying to use a resistor.
there are native 6v coils and native 12v coils.
a napa IC 7 is a native 6v oil.. runs on 6v, no resistor..
a napa ic14sb is a native 12v coil.. runs on 12v with no resistor.
putting a 12v coil on a 6c tractor is asking for problems and weak spark.
putting a 6v coil on a 12v tractor just means you need a resistor inline. many use a resistor or resistor wire and an ignition bypass setup or thermal coeficient ballast resistor to accomplish easy starts.
put a 6v coil on that 6v tractor.
TSC even has 6v coils.. probably cheaper than that napa ic7
   / 6V tractor with 12V coil #7
Here is a picture of the distributor set up on Dan's tractor. Might help clear up any further confusion.
   / 6V tractor with 12V coil #8
what are we suposed to be seeing.. it's a pretty common site to see a ign coil seting like that near a dizzy... nothing too special about it???
   / 6V tractor with 12V coil #9
You weren't supposed to see anything unusual. I just felt like posting a photo of it.
   / 6V tractor with 12V coil #10
oh, ok. nice photo then. paint looks great.
as much as I love ford red and grey and blue.. I also love the IH reds, case orange ( flambeau ), and the persion orange allis's
looking at a wd on the side of the road longingly right now.. :) it's calling to me...
2009 Ford Explorer SUV (A44572)
2009 Ford Explorer...
2006 LONESTAR UTILITY TRAILER (A45333)
2006 LONESTAR...
Daewoo SL220LC III - Excavator (A42203)
Daewoo SL220LC III...
Bush Hog 295 (A44502)
(2) New/Unused Welding Helmets (A44391)
(2) New/Unused...
2012 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2012 ADVANCE...
