69 Ford Model 2000 gas
   / 69 Ford Model 2000 gas #1
jgregory
Louisiana
1969 Ford Tractor 2000 gas
I have 1969 ford 2000 3cylinder gas burner I was playing with what I beleive was the draft lever(directly under seat on right)I think it was in a vertical position. I pushed it down it was very hard, now when I put it back up to vertical position I cannot control the up and down with my lift lever. Everything before was working fine it sounded like the hydraulic was making a noise/whining so I checked the fill plug and nothing came out I bought hydraulic oil and filled till it came out the fill plug. Then I started having problems. NEED Help thanks in advance
Since then I changed the hydraulic fluid still same thing. I put the bush hog up about a foot yesterday and it stayed utntil I put it down today.
   / 69 Ford Model 2000 gas #2
If your draft linkage was real hard to move, I wonder if you don't have some corrosion or rusty springs / linkages.
Hit the NH site and look at the exploded diagram of the lift cover for that model.. you'll see what i mean.
If you have a parts manual, it will be listed in there as well... Page 88 figure 05A01
Might be something that moved then didn't move back..
Soundguy
Thanks I need all the help I can get
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
Unused Delta Crash...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
