67 Ford 2000 lift arms blow out / now leaking
   / 67 Ford 2000 lift arms blow out / now leaking #1
maizeandblue
pensacola, fl
2006 Mahindra 3525 w/ FEL
So, I finished tilling some summer plots and was about to load the tractor up for the day. I pulled the tractor up to the back of the trailer shifted into neutral to get off and move some stuff off the trailer. As I started to move whatever it was in the way, I noticed a different sound/tone from tractor (almost a deep sounding chatter/shutter). I immediately turned toward the tractor and noticed the tiller being lifted back up, but it appeared to be a shuttering type of upward movement. I figured the lift was just bringing it back up. I get it on the trailer and start to bind it down and notice a fresh drop of oil at the backend of the tractor. I start looking the tractor over and I notice there is fresh oil (looked as if it sprayed from both lift arms). While it is not pouring from there now, it is leaking quite a bit. In the 1hr drive back to house I have about a basketball size oil stain on the trailer. I have the books on my tractor but with age of the tractor they are repros not originals so making heads or tails of some pictures is nearly impossible.
I tried looking up some videos on youtube because it seems everyone is making videos of repairs, mods, and whatever. The closest thing I found was a top plate rebuild of an 8n. However, they didn't do any work to the lift arms.
Now my questions.
1. Are there seals at the upper lift arms? I have tried locating some from vendors I normally buy parts from but have not seen any.
2. Do I need/should I rebuild the top plate (piston/housing) as well?
3. Anyone know if the top plate layout and functionality of an 8n and 2000 are similar? Not for parts, I know they are different but was wondering if I could use the video as reference if I rebuild the top plate.
update:
Pulled filler caps and the following is what I have found.
1. Hydraulic reservoir was slam full to the cap. (I haven't put any in and I know where the level indicator is at)
2. Transmission / gear box appeared to be little low (not much).
3. Siphoned off about 5.5-6 gallons. Put about 1 gal back into transmission.
4. Going to move onto good level ground tomorrow and check all levels and will go from there.
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
UNUSED CFG QUICK ATTACH HYD HAMMER (A51248)
UNUSED CFG QUICK...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
