6610 ford no crank
/ 6610 ford no crank #1
fishnfreddy
Van Buren, AR
6610 ford
I sure could use a wiring diagram for starting circuit. can anybody help with one? signal leaves ignition switch but doesn't make it to nuetral safety switch (in transmission) or to starter solenoid. can run wire straight to solenoid from key switch and starts great. would like to repair circuit correctly so that safety features work.
/ 6610 ford no crank #2
bottom line.
find the start line off the key switch. ie the spring loaded one.. and that is what goes to NS switch.
use test lamp and / or vom and check switch, then wire to NS, then NS, and then wire to solenoid.
it's one of them. etc.
2019 CENTEX TRAILER 16' COOL DOWN TRAILER (A65643)
2019 CENTEX...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
New Idea 5409 Disc Mower (A66408)
New Idea 5409 Disc...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
Massey Ferguson Model 66 Hay Rake (A65640)
Massey Ferguson...
