66 MF 135 w Z145 Gas - Generator w/ Tach Drive Replacement Alternator Conversion
   / 66 MF 135 w Z145 Gas - Generator w/ Tach Drive Replacement Alternator Conversion #1
nolarefugee
Bronze Member
MF 135, Ford 4000
I'm looking to replace my generator with an alternator. The tach runs off the tach drive mounted on the back of the generator.
I have been looking and found some on ebay, but don't know if they will fit.
New 1 Wire Alternator Massey 7 8 18 1:D 11 115 165 175 with Tach Hookup | eBay
and
New Alternator for Allis Chalmers Tractor 16 17 175 18 185 19 2 21 22 | eBay
Has anyone else done this conversion with success?
Any suggestions on where I can find one?
Should I just get a generic one wire alt and forego the tach?
   / 66 MF 135 w Z145 Gas - Generator w/ Tach Drive Replacement Alternator Conversion #2
Look on eBay for a Ford alternator with tachdrive. There was a vendor goes by cheaptractorparts out of Kentucky is where I bought mine for my 135. I modified the existing bracket and also replaced my tach. Be sure to ask which direction the tach runs so as to match your existing tach. The alternator is a Delco 10si which is a very common alternator. Sometimes they have to build to order. It will run you a bit over $200. There is a Ford alt w/tach on eBay right now which will work for you if the tach is output the correct direction.
Poking this thread again. I STILL haven't replaced my generator. Procrastination I guess.
Does anyone know the Part Number for the original 66 MF135 z145 gas engine's Generator?
   / 66 MF 135 w Z145 Gas - Generator w/ Tach Drive Replacement Alternator Conversion #4
193517M91 1 (A) Generator Assembly (Delco Remy #1100-436
OR
509057M91 1 Generator Assembly (Delco Remy #1100-439)
   / 66 MF 135 w Z145 Gas - Generator w/ Tach Drive Replacement Alternator Conversion #5
Why don't you just get the gen. rebuilt??? Probably less than $100....and you get to keep your tach...Bobg in VA
30ft Highway Trailer Co. Lowboy (A53473)
30ft Highway...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2013 HYUNDAI VC2530152 53FT DRY VAN TRAILER (A53426)
2013 HYUNDAI...
