650G-won't run
   / 650G-won't run #1
gpb
The tractor has set for year. It used to fire right up. It will still run if I continue to shoot gas into the carb. I drained all the old gas and put in new. There was no change. I'm guessing it needs a carb rebuild. If so, what kit is needed and where do I get it?
   / 650G-won't run #2
you may not need any kit as yet.the trouble may be that when gas sits in the carb for long periods the gas turns to varnish and blocks the jets also closes the float valve.what you have to do is remove the float bowl and clean with carb spray free up the float valve and clean out the jets.then put it back together and you should get it running.If you need parts go to www.satohparts.com
   / 650G-won't run #3
It is common for the accelerator pump to go bad on these carbs.
   / 650G-won't run
Thanks, the pump had seized. I cleaned it and got it working again and the tractor runs.
   / 650G-won't run
Thanks for the info in what can happen when it sets a long time. I got it running again and I did not have to get a rebuild kit. You guys saved me.
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
2015 Ford F-350 Dump Truck (A51691)
2015 Ford F-350...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
