65 MF 135 Swept front axle
   / 65 MF 135 Swept front axle #1
Gpops
Troup, Texas
1965 MF135, Kubota B2301HSD
Looking for information regarding the swept front axle on 135s. My '65 has a single pressed in bushing that does not cover the width of the axle or the associated pivot pin. Did later models use a longer bushing? Mine shows wear that indicates the pivot pin was tilting or canting in the axle as if the bushing wasn't giving support over enough area. Has anyone put in an additional bushing from the other side? Thanks
   / 65 MF 135 Swept front axle #2
They came from the factory with the short axle bushing, and I'd imagine that you saw excessive wear like I found when I removed the front axle bushing on my MF-135 tractor. There is a wider bushing available and I have one. As a matter of fact, you're in luck because I'm planning to press the new bushing into my axle later today and will post pictures of the process on my Massey Ferguson 135 tractor Restoration Project thread, also linked in my sig.
In the mean time, you can see additional pictures and information about the front axle bushing in my previous posts linked below.
http://www.tractorbynet.com/forums/...y-1966-massey-135-tractor-11.html#post2857373
http://www.tractorbynet.com/forums/...y-1966-massey-135-tractor-11.html#post2857475
http://www.tractorbynet.com/forums/...y-1966-massey-135-tractor-13.html#post2873629
For a minute I thought you had taken pics of my parts!! Thanks for the reply and info, I now know what I am going to do.
   / 65 MF 135 Swept front axle #4
2014 CHRYSLER Town and Country (A50324)
2014 CHRYSLER Town...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
