6410 Park / Neutral Switch
/ 6410 Park / Neutral Switch #1
bub6410
Cynthiana, KY
JD 6410, JD 2020, JD X475, JD x485, JD 345
I have a 6410 that quit going forward and reverse. I changed the power reverse unit and have a new park / neutral switch to install, not sure how to wire it up since new switch has different color wires. Checked all solenoids on the tranny already, checked good. Can never get voltage on either the forward or reverse solenoid. Will have voltage on the enable solenoid until i move the shuttle in either direction then the voltage drops out. Thinking that my wiring of the switch is causing this, but have tried different wiring scenarios. Checked fluid pressure (150 psi) and pressure switch. When shuttle lever is moved to either position it just beeps. Any suggestions please.
/ 6410 Park / Neutral Switch #2
The park neutral switch is to allow the tractor to start. There is another thread in JD AG tractors about a 6410 with the same problem. Tuned out to be a bad relay.
/ 6410 Park / Neutral Switch #3
im having same problem. what did you have too do to fix it
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2007 Toyota Rav4 (A64557)
2007 Toyota Rav4...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
