641 cylinder compression
   / 641 cylinder compression #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
My 641 blows a lot of blue smoke so I just checked the compression. All cylinders are right around 115 lbs. The shop manual I bought lists the cylinder compression as 205 PSI @ 1000rpm. 205 seems really high for a motor that old. Can someone tell me if the 205 # is correct?
Thanks,
Bob W
2 DISC TILLER W/ FARMALL MOUNTS (A52708)
2 DISC TILLER W/...
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
1292 (A58374)
1292 (A58374)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
