64 Fordson Super Dexta PTO Problem
   / 64 Fordson Super Dexta PTO Problem #1
fireman4074
Bronze Member
MF 231S
I am having trouble with my pto when I engage it for example bushhogging it will disengage on its own. It will stay engage until it get in some high grass unless i raise it up. If this is the problem, how do I adjust it. The tractor is a diesel 3 cylinder. I have tried to use a heavy spring to keep it in gear but now that wont work either. It will grind. I check the in/out play on the pto shaft. It is tight with no play. Is there a clutch that need adjusting. Have anyone had this problem and got it fix? IF so, is this a DIY job or shop fix? Do anyone have diagram of the internal parts?
   / 64 Fordson Super Dexta PTO Problem #2
i'm not up on the fordsons.. but if a mechanical sliding colar engaged pto clutch.....bad news.. if there is no in / out play, AND a bunji won't keep it engaged.. you are probably not looking at soemthing like a detent type fix. I'd be looking at the dog clutch..
Soundguy is their any repair manual that you know of that might be helpful in doing this project.
   / 64 Fordson Super Dexta PTO Problem #4
1 pallet of hydraulic cylinders/small auger (A53117)
1 pallet of...
1779 (A51248)
1779 (A51248)
Unused 2025 Electric Cart (A51694)
Unused 2025...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
