Mowing 62D cracked on a 2320
   / 62D cracked on a 2320 #1
swomack
Tennessee
John Deere 2320
Has anyone had their 62D MMM deck crack? Mine, which up until two weeks ago has been used very little since it was not installed properly at the dealer, has a stress crack near the bottom lip a couple inches behind the left front caster. What can I expect JD to do about it?
   / 62D cracked on a 2320 #2
I have not heard of a failure like that...I am sure JD will make it right.
   / 62D cracked on a 2320 #3
Ours has been flawless. As KennyD stated I would expect JD to make it right for you.
   / 62D cracked on a 2320 #4
They may say a foreign object struck it at high speed and made a small fracture in the case which is hardened to withstand years of service. this will not effect the use or ability to perform well. I would let the dealer know about it and if it became a serious problem he could weld and paint it over a period where you didn't have a need for it. Its only metal and it can be repaired. JDs not going to give you a 2k deck over this miner flaw. Keep in mind... it cuts grass, not a show piece.
   / 62D cracked on a 2320 #5
If it is as you explained it, Deere will make it right for you.
Your friendly Deere dealer will take care of his/her good customers working with Deere.
   / 62D cracked on a 2320 #6
Have you talked to the dealer?
Are they going to do anything for you?
Deere 317G (A50120)
Deere 317G (A50120)
Tarter 4' 3 pt Box Blade (A50515)
Tarter 4' 3 pt Box...
Massey Ferguson 65 Tractor (AS IS) (A50774)
Massey Ferguson 65...
2002 Kountry Star Motorhome (A50324)
2002 Kountry Star...
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
