62C or 54C Mower Deck Spindle Overhaul
   / 62C or 54C Mower Deck Spindle Overhaul #1
Mad_River
NE Ohio
John Deere 1023E with 60D mower and 120R loader
I decided I better replace the 6204 open deep groove bearings in my X495 deck. 1800hrs before needing bearings is pretty darn impressive. I found some Nachi Japanese made bearings on eBay for half the cost of the Koyo Chinese versions JD sells. I had to order the seal kits (each comes with 2 seals) from JD. I tried my best to get the spindle nuts off, but the blade kept spinning so I had to take the whole deck A (vice just the spindle housings) to the dealer. If anyone has had this done, how much should the labor be?
   / 62C or 54C Mower Deck Spindle Overhaul #2
:eek: At least an hour or $75, but with dealers it's pot luck.
They are sometimes not easy to rebuild.
I think the entire assembly is # AM135349 and are $ 60.65 each from GFP.
I find that JD has decent prices on bearings. They must buy a gazillion of these from Koyo.
JD bearings were @ $14 and the ones I got were @$8. I hope labor is under $100. Thanks for the info.
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
Livestock Hay Ring - Round Bale Feeder (A55218)
Livestock Hay Ring...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A54757)
UNUSED WOLVERINE...
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A55758)
30pc. 16ft.x 3ft...
