Grading 62c blade options???
   / 62c blade options??? #1
megotatractor
Veteran Member
New Richland, Minnesota
JD 2210
what options are available in the aftermarket for the 62c deck for blades? does anyone know what the shaft size and blade length offhand?
   / 62c blade options??? #2
Don't know the sizes, but my dealer installed Gator blades at the 50 hr servicing. I like the results even better than the factory blades which were quite good. /forums/images/graemlins/tongue.gif
   / 62c blade options??? #3
I will get getting a set of Gator Blades for my 54C deck next week. I have had good luck with the factory blades, but on all decks I have ever had I have habitiual problems with the deck loading up. I have a very coarse lawn (more honestly a short mown field).
JD offers the standard lift (factory) and high lift blades (higher lift but not slotted like Gators). I've heard nothing but good about the Gators, so that's where I'm goin'.
   / 62c blade options??? #4
Hey IOWA2210 - what's the Gator blade number for the 54C? I'm thinking of doing the same thing with my 54C, but, all I've found are Gator 'mulching' blades, which I'm not really after. The OEM # on my blades is M143520. Does anyone know of a blade cross-reference chart somewhere? /forums/images/graemlins/confused.gif
   / 62c blade options??? #5
Here is one link to a gator cross reference. And here is the complete Oregon listing for blades. They make the Gator line of blades. It is in section II page 22. Listed in order under John Deere, then by length.
   / 62c blade options??? #6
I guess I thought all Gator blades were considered the "mulching" blade. I know they make a regular and a magnum blade. I have the regulars. But of course didn't look at the part numbers before I started to use them. Hmmmmph, well when I'm down to get the supplies for my 50hr service, I'll see if the dealer can pull the a part number on those blades.
   / 62c blade options??? #7
OOPSIE!! My bad. All the Gators are mulchers, it appears, now that I finally got that .pdf Oregon file to load.
I'm going for the Gator #91-470 Mulcher Magnums. /forums/images/graemlins/laugh.gif Hey, with "Magnum" in the name, it's gotta be great, right? /forums/images/graemlins/grin.gif
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2015 Toro Z Master Professional 64in Zero Turn Mower (A50322)
2015 Toro Z Master...
UNSUED CFG INDUSTRIAL SSHH680 BREAKER (A51244)
UNSUED CFG...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52128)
Quick Attach Skid...
