6284 and 811 mmm mower need drive shaft parts
/ 6284 and 811 mmm mower need drive shaft parts #1
scoops
Bronze Member
Pittsburgh
Can anyone offer a parts diagram for the drive shaft that
connects to the 811 mmm mower deck? I beleive this deck worked on 5000 and 6000 series cub cadets
Somehow the bolt that attaches the shaft to the mower came loose
and lodged itself into the u joint closest to the transmission and sheared the u joint.
I cant seem to locate a parts diagram for this drive shaft anywhere.
I found a part# but not even sure if this is it or not: mtd-wm-65689 thats for a u joint.
I would even be willing to buy the whole half shaft if available anywhere
any help would be appreciated.
/ 6284 and 811 mmm mower need drive shaft parts #2
I have been able to locate your parts diagram on the cub cadet website. Not sure if this link will work.
ARIPartFinder
Thanks, but I need the diagram to the driveshaft, this is the shaft that is to the left of
part # 5.
/ 6284 and 811 mmm mower need drive shaft parts #4
Look at the other diagrams for that unit i am sure its on the site.
/ 6284 and 811 mmm mower need drive shaft parts #5
Ok here is another link. You will have to look in the drop down sections to find the area your talking about.ARIPartFinder
Thanks, finally found the shaft under 831 deck lift kit. the part # is 717-3521a but it doesn't break down the parts for the shaft. At 489 I think I'll pop out the
ujoint and mic it myself, all I need is the u joint.
Thanks for your help BuilderML.
/ 6284 and 811 mmm mower need drive shaft parts #7
No problem :drink: good luck with your fix. If you take it down to napa i would think they should be able to match it up to something.
I just wanted to give a quick update.
The shaft from mtd is about 500.
I just happened to see a half shaft on ebay it was 15 spline for 99, it said it was from an international cub cadet h-42 snowblower, so I decided to buy it.
It came in today, and what do you know, it's the same exact part.
The part # appears to be 1254773-c1 which is now part # ha-9177 and it retails for 179
Maybe this will help someone in the future.
(2) BKT TR-387 TIRES (A60432)
(2) BKT TR-387...
Bobcat A770 (A60462)
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
