6200 wont start!! please help feed my cows!
   / 6200 wont start!! please help feed my cows! #11
JWillia2,
jwillia2 said:
thanks for all the reply's... Yes it does smoke while it was turning over today... it just wont fire off... lots of white smoke. it wouldnt start today but my 5400 fired first lick.... it was only 35 today... I live in southwest VA... do you think the check valve would help that much???
Does the tractor have closed center hydraulics? If so, a bad de-stroker valve might cause the problem that you describe. The de-stroker valve is designed to prevent the hydraulic pump from trying to build pressure while cranking.
On the older new generation tractors (10 and 20 series) you can work around this on a cold morning by turning the steering wheel back and forth while cranking. Might be worth a try the next cold morning.
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
2022 Third Coast Reversible Plate Compactor (A54865)
2022 Third Coast...
48" Farm Jack (A53316)
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
Case 1083 20ft Corn Head (A55302)
Case 1083 20ft...
