60" or 72" Grapple bucket Is the question
   / 60" or 72" Grapple bucket Is the question #1
mx377
Mich
LS XR4046H
Hi, I have a 46hp LS XR4046 on the way. Do I go with a 60" or 72" Grapple Bucket? Main use will be removing logs from woodlots & General clean up.
Thanks for your thoughts.
   / 60" or 72" Grapple bucket Is the question #2
I went with a 60" on my Kioti from MIE.Error
Don't know why it says error but the link still works.
   / 60" or 72" Grapple bucket Is the question #3
I went with the 60" also for the Montana, which is the same as your tractor just an 09 with the Mitsubishi engine (and of course it's green). It doesn't cover the tire width but I have found that just doesn't matter with a grapple. The weight is more of a concern especially if you are lifting logs or other heavy items it allows you that little extra lifting capacity!
   / 60" or 72" Grapple bucket Is the question #4
I use a 60" on my 7520 to move logs and trimmings and uproot brush in woods and semi cleared areas. I have never wanted it to be wider and frequently wished it were narrower to improve nimbleness and positioning options.
larry
   / 60" or 72" Grapple bucket Is the question #5
I have a 73 inch grapple on my L4600 it works fine but I think I would rather have a 60 inch but would want dual clamps the larger grapple is very heavy
   / 60" or 72" Grapple bucket Is the question #6
I have a 73 with dual clamps on my Kubota 60 horse and if I had it to do over would get a smaller lighter one as the one I have weighs about a thousand pounds which limits the size log you can pick up, Luckily I have a larger tractor also.
   / 60" or 72" Grapple bucket Is the question #7
Curious ... why are 2 clamps needed? I have just a narrow one in the center. What superior function am I losing?
   / 60" or 72" Grapple bucket Is the question #8
I went with a 60" single lid for my R4047. Seems to be a good matchup.
I'm Thinking of going with the 60" with duel clamps.
   / 60" or 72" Grapple bucket Is the question #10
Careful. Its easy to get into the logical progression to the effect that - "If a little is good more is better, and too much is just right."
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
2009 Ford E-350 Cargo Van (A50323)
2009 Ford E-350...
2015 ISUZU NPR 16FT BOX TRUCK (A52141)
2015 ISUZU NPR...
John Deere 4455 (A50120)
John Deere 4455...
