60" MMM - Uneven Cut
   / 60" MMM - Uneven Cut #1
Chyzikj
Chesapeake, VA
BX2200
60\" MMM - Uneven Cut
I bought a brand new 60" MMM for my BX2200 last April. The deck has NEVER given me a nice clean cut. It leaves a poorly cut swath about 6" wide just to the left of center. The swath appears to be cut, but is longer than the rest of the cut. It looks even worse a few days later when the grass has grown up some more. Then, you can see a distinct difference in the height of the grass.
I have checked the air pressure in the tires, leveled the deck (several times), sharpened the blades, switched the blades to different locations, and tried different cutting heights - no difference. I brought the mower to the local dealership twice. The first time they said there was nothing wrong, the second time they said the deck was not level (it WAS level). Both times we took it out back for a trial cut, but they were cutting in a field, not a lawn, and it was too difficult to see the problem with the type of grass in the field.
The warranty on the deck is up next month and I really don't know what else to do. I like everything else about the tractor and the deck - fast, powerful, etc. but the cut is just not that good; especially considering the price of the deck.
Anyone out there have a similar experience? Any suggestions?
Thanks in advance for your replies.
Jeff - Chesapeake, VA
   / 60" MMM - Uneven Cut #2
Re: 60\" MMM - Uneven Cut
My neighbor had the same problem with a JD rider. Had the dealer over a few times to figure out what was wrong. Turned out to be a bad bearing in the spindle. It would allow the belt to slip by dragging. The one spindle just didn't get up to speed as the others did. Once the new spindle went in the problem went away.
   / 60" MMM - Uneven Cut #3
If that was the case with the JD, then it will be easy enough to swap the spindles from side to side to see if the problem goes to another blade. As long as you have documented the problem with the dealer in the past, then you should have no problem with Kubota dealing with this when it is out of warranty. They have to realize that the deck isn't used most of the year where you live. I would put a call into the Kubota zone manager for the area where you live and discuss the problem with him and ask him to open a file on the problem. Make sure to get the file number. That way, you will have recourse as soon as the mowing season starts this year. If I understand the problem correctly, the dealership never did anything other than leveling the deck. The way you describe the problem would preclude this being a deck leveling problem since it is a 6" swath. This is more likely a 1/2 of a blade tip problem in my opinion. I would be inclined to agree with the bearings as the likely culprit and a disassembly will verify that quickly. This isn't rocket science, but getting the dealer to do it might be. Good luck, it sounds like you are going to need it.. By the way, I have the same deck and it give me a beautiful cut and I am very satisfied with its performance. The only thing that I don't like about it is that there seems to be some sort of rock magnet that draws the blades to every rock in the lawn that I didn't know was there. /forums/images/graemlins/frown.gif
   / 60" MMM - Uneven Cut #4
My BX has NEVER given me as manicured a cut as my former Deere LX277 lawn tractor that I sold to move up to the BX. While I love the versatility of my BX (it has been one amazing little workhorse) the quality of the cut isn't that great. I have read that decks with 3 blades VS. 2 blades are nortorious for that. Just my opinion.
   / 60" MMM - Uneven Cut #5
Are the blades on right side up?, are they in the same plane?, if not the deck is bent. Is a blade backwards? Is the belt slipping? Are the blades uniformly sharp? You don't happen to have a mulching kit or bagger on it do you?
Do you run the mower fast enough, try full PTO speed.
I suspect your front tires are compacting the grass as you mow over it. My BX and even my 2410 give a good cut but it ain't gonna be the same as a dedicated lawnmower, both are to heavy and flatten the grass beneath the wheels more than previous ride-on tractor styled lawn mowers I have owned. If I mow fairly tall grass I can see my front wheels tracks the next day. Solution, sharp blades, run the deck faster, mow more often not allowing the grass to get tall enough to fall over, mow only when dry. J
- YES
Are they in the same plane?, if not the deck is bent.
- I have leveled the deck per the manual. How can I verify the plane?
- NO
-NO
_ Yes, just sharpened them
- No
- Tried various speeds. Does not seem to be a factor. However, the thicker the grass the more pronounced the problem is.
- I thought so too at first. But why only on one side? Besides, the swath does not seem to line up with the left tire.
   / 60" MMM - Uneven Cut #7
You could have possibly sheared a key off on the the shaft. The grass would give enough resistance to slow or stop the blade but the pulley woud still be spinning. To check, wedge the blade in question so it wont spin. Then pull on one of the other blades by hand and watch to see what happens. If the pulley still spins then you have sheared a key. It will most likely need a new shaft if this is the case. If not, I would take the others suggestion and check the bearings.
   / 60" MMM - Uneven Cut #8
It might help to fill in your profile. You never know when another member might live around the corner from you and could possibly have the same mower deck and be willing to try your deck on his machine. That would give proof positive if it is your deck or your machine that is at fault. There are lots of possibilities and all we can do is to take a stab at the problem. If you help us with some profile information, possibly some member might be close enough to give you more than typing help. Here in the Northeast CT area, we help each other all the time with actual projects.
Update -
I called my local dealer and asked the (new) service manager for the zone managers phone number. That seemed to get their attention since they now "appear" very interested in solving my problem. I will be bringing the tractor there this week for them to look at. We'll see how much interest they really have.
While I have it there, I will ask them about my recently snapped air filter bracket, my leaking diesel tank, my throttle lever that won't stay at full throttle, and my sticking hydro pedal. Apparently, all common problems with the BX according to posts on the forum.
I'll keep you all posted. (I'll update my profile too)
Jeff
   / 60" MMM - Uneven Cut #10
What's the verdict?
I notice this with the 60" MMM on my B7500. Here's what I've figured out/noticed.
I get the same thing happening.... The MMM don't lift as well if the grass is wet, heavy. After mowing a round you see the streak and it's under one of the front tires (depending on the direction you mow).
If the grass is dry and been cut on a regular basis I don't see the problem.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53473)
Kuhns AE10 Small...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
