60" Kubota MMM
   / 60" Kubota MMM #1
John762
Tennessee
Kubota/7610
60\" Kubota MMM
Can anyone give me the blade bolt head size?
I have received a gift certificate from Sears and
would like to get a socket and breaker bar for my
mower.
It is a RCK60-24B Kubota model.
Thanks,
John
   / 60" Kubota MMM #2
Re: 60\" Kubota MMM
Don't know if this will help you much.........
I needed metric sockets for my BX2200 (mainly for the lug nuts). I went to Harbor Freight and bought a 1/2 drive SET of deep impact sockets for like $15. This gave me sockets for the lug nuts, the mower blades and probably all I will need for the unit.
When I was younger, I would never consider cheap tools, but I'm at the stage in my life that cheap tools will likely last longer than I will need to use them.......... Grim, but probably true.
My best wishes,
Ron
   / 60" Kubota MMM #3
Re: 60\" Kubota MMM
30mm.
   / 60" Kubota MMM #4
Re: 60\" Kubota MMM
</font><font color="blue" class="small">( When I was younger, I would never consider cheap tools, but I'm at the stage in my life that cheap tools will likely last longer than I will need to use them.......... Grim, but probably true.)</font>
Do you have any children or other inheritors? My boys will probably fight over my tools and shop when I go. I don't have a ton of tools, but I believe that real value lies in good quality, be it tools, cars, trucks, tractors, or whatever.
   / 60" Kubota MMM #5
Re: 60\" Kubota MMM
Ron, I'm with you on the cheapo tools - on occasion. I like the Craftsman and Snap-On stuff alot - but I'm not going to pay that kind of money for a one-two time use tool.
So, I have been using some "Snap-Off" tools, contrary to my better judgement. If I had a cheaper tractor I could afford better tools, but then I wouldn't need them, time for more medication.
/forums/images/graemlins/wink.gif
   / 60" Kubota MMM #6
Re: 60\" Kubota MMM
Ah, we have a son and daughter, but I have enough tools for 5+ kids, so there won't be any fighting. I used to be a farm equipment mechanic, so I have some really good tools as a main set, then some cheaper stuff for the car and truck, and more stuff I seldom use.
Not to worry about passing tools along...........
Ron
   / 60" Kubota MMM #7
Re: 60\" Kubota MMM
I have a RCK60B-22BX 60 INCH MMM and the manual calls out 30.2 mm or 1-3/16 for the nut (probably the same as your model).
I bought a 1-3/16 air impact socket at NAPA and it fits perfect.
John
   / 60" Kubota MMM #8
Re: 60\" Kubota MMM
I'm with you on the cheap tools. If they do the job that's all that is required. I use to change some U-joints on small Cat fork lifts at work and the only thing that would do it was a snap on, that is that I could find. It was a big fine tread bolt that a 12 point 5\16 socket would fit and it was a 1\4 in drive. That thing took a beating getting the u joint loose because the were tight and not hardly any room to work. Cheap ones just would not stand the pressure /forums/images/graemlins/smirk.gif
   / 60" Kubota MMM #9
Re: 60\" Kubota MMM
</font><font color="blue" class="small">( I don't have a ton of tools, but I believe that real value lies in good quality, be it tools, cars, trucks, tractors, or whatever.)</font>
Very true. I work with tools for a living and I have a lot of different brands but mostly Craftsman and Snap-On. There is a difference. But there is also a difference between somebody who might use a screwdriver once a month and somebody that uses one 20 times a day. I'm not afraid to buy cheap if it's something I know I will hardly ever use. But as for the tools I use on a day to day basis... the money is worth it. I consider Craftsman to be a cheap brand but that do make some pretty good tools. Snap-On, Mack, Matco... they are expensive... but you get what you pay for. One day I was working on a fire truck at work and there were stainless screws going into aluminum. Not the best combination. I tryed removing them with a #2 phillips Craftsman screwdriver and didn't have any luck... then I picked up a #2 Snap-On screwdriver and out they came! That right there impressed me and suprised me that the Snap-On would get it out but the Craftsman wouldn't!
   / 60" Kubota MMM #10
Re: 60\" Kubota MMM
I'm not endorsing any store or tool, but I got a set of Stanley 1/2" sockets at WalMart that are 1 inch up to about 1 3/4 inches that work just great. The 1-3/16 socket works great on the mower bolt and I prefer to use my air impact to remove the bolt over a breaker bar.
MISSION 4X3X14 CENTRIFUGAL PUMP (A53843)
MISSION 4X3X14...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
