60" deck removal procedure needed
   / 60" deck removal procedure needed #1
rbig
Need the Cub Cadet procedure for removing my 60" deck in my 3205.
I can do it without the procedure, but figure the procedure might make the job a little easier.
   / 60" deck removal procedure needed #2
Slightly different design, but on my 2544:
1) I place a 1"x2"x3ft long pc of wood under the nose roller.
2) Lower the deck as low as it will go.
3) Release the drive belt.
4) Release the left and right lift arm spring loaded J-pins.
5) Lift up on the pc of wood to raise the deck and release the nose bracket.
6) Slide the deck out from the side.
Takes me about 2min. Thing is, my 44" only weighs about 100lbs fully dressed. Your 60" is probably 2-3x that.
Joel
The 60" has a shaft to be disconnected instead of belts.
I think your process will work for my deck. It's basically the same many other tractors use.
I always like to see if there's any detail in the factory procedure I might not know, when I can.
Thanks for the process. Bet it'll work fine on my situation.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2021 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2021 Big Tex...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
