60" Deck blade alignment
   / 60" Deck blade alignment #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
60\" Deck blade alignment
I'm getting my 60" dexk for the BX ready for spring. After a new set of blades and oil for deck, I'm trying to decipher the blade position issue. I followed the picture in the manual, but when you do, the center blade and the blade next to the discharge will cross tip to tip.
Is this ok or should the blades at all times never cross tip to tip.
Also, does blade rotation have any impact of balance or harmonics on the deck. I would think that any placement that keeps the blades from ever going tip to tip is best.
Suggestions or ideas?
I called the local shop and they just said bring it in and they'll set it up. For major bucks an hour of course.
   / 60" Deck blade alignment #3
Re: 60\" Deck blade alignment
I don't think that blade position matters. There is no way to maintain blade position when the spindles are driven by a belt. There will always be a certian amount of slippage in a belt driven system.
Did you see a spec. somewhere on the relative position of the blades? There is no mention in my manual.
John
   / 60" Deck blade alignment #4
John
   / 60" Deck blade alignment #5
If you check out the "mower deck manual" you will find a diagram of the relative position of the blades. Thats what I did when I removed and replaced the blades for sharpening and no problems.
   / 60" Deck blade alignment #6
   / 60" Deck blade alignment #7
The proceedure I use seems to give me pretty good results. Theres no noticable vibrations nor loud noises and the mower runs smoother than any of my previous lawn mowers.
Settings are done with the MMM standing upright on a set of mower axles.
I set the righthand blade (furthest from the discharge opening) to where it's pointing fore & aft. 6 & 12 oclock position.
I set the middle blade slightly before at 1 & 7 oclock position.
I set the left hand blade before the middle blade at the 2 & 8 oclock position.
My reasoning is that this staggering increases the discharge flow of the clippings as the clippings get additional slicing and a push outward from the next blade. I can't prove that it does but then again, I don't have any problems so it doesn't hurt.
There will be points where the tips overlap but I don't think this is a bad thing.
Now the timing deck on my old WheelHorse is a different story /forums/images/graemlins/grin.gif
Volfandt
   / 60" Deck blade alignment #8
Volfandt
   / 60" Deck blade alignment #9
Mike
I must have an outdated manual, mine is dated May 2002. There is no mention of relative blade position in my manual. What is the date on your manual?
I still don't understand how you could maintain relative position with a belt drive.
   / 60" Deck blade alignment #10
Mike
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
Ford F-550 Bucket Truck (A51692)
Ford F-550 Bucket...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
2016 Isuzu NPR Cab and Chassis (A51692)
2016 Isuzu NPR Cab...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
