Grading 60" Box Blade on a B7500
   / 60" Box Blade on a B7500 #1
garbageman
Orange County, NY
Kubota 7500
60\" Box Blade on a B7500
I was wondering what size Box Blade would work best with a 7500. Kubota states 54" max. Does anyone use a 60" and how
does it work?
Thanks,
Ray
   / 60" Box Blade on a B7500 #2
Re: 60\" Box Blade on a B7500
I've got a 60" King Kutter BB that I use behind my B2400 (24hp). I believe the manual calls for 54" max behind this unit also. I can tell you that the tractor strains using this size blade as low range is mandatory and with the rippers at full depth, it doesn't take much to stop it in it's tracks! The bright side is that my Kubota seems to pull it better than my Father-in-Laws brand new 4115 Deere! /forums/images/graemlins/grin.gif All said I think if you can find a reasonably priced 54" BB you'll be happier than with the 60" unit as far as tractor performance.
I was looking at the KK 60" blade. They also sell a 48" blade but I'm not sure if it will cover the rear tires. I have not scene too many 54" blades. I need to do some "light" grading behind the barn. If it takes more passes, so be it, it more seat time.
   / 60" Box Blade on a B7500 #4
If you love you B7500 get a 48-52".
A 60" is HUGE when full of dirt and gravel.
They recommend a type of oil and you use it..not nothing thicker...
   / 60" Box Blade on a B7500 #5
I use a 48 inch on my 2410 and it works great and it does cover the tracks with the wheels in the standard position. I would not get a 60 for that size tractor except for use as a grader--maybe. J
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2013 MACK GU713 (A50854)
2013 MACK GU713...
Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
Ingersoll Rand 185...
2012 FORD F-650 (A50854)
2012 FORD F-650...
