60" 7 iron deck on a 68" wide 3320 series tractor?
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #1
Ramairfreak98ss
Columbus, NJ
Ferris/Simplicity/John Deere
60\" 7 iron deck on a 68\" wide 3320 series tractor?
Its the only deck option?
If the rear tires are almost 69" wide, why would you not use the 72" 7 iron deck? I cant see this being too productive if the tires are running over some grass on every pass since you dont cut a full 60" wide each strip, maybe 56~ since you over lap a hair to not miss any.?
Re: 60\" 7 iron deck on a 68\" wide 3320 series tractor?
ok im a little slow today, just realize you can get a 72" 7 iron deck on it... but why even offer a 60"?
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #3
Here is the better question...what exactly is "7 Iron"?!?!
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #4
.177" thick steel deck. Here is a link to a brochure on the deck. Click Here
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #5
so if I am reading this post right your cutting deck should be wider than the wheels, is it following the same thought as a rear blade should be wider than the wheel base to it does not leave tire marks. I am thinking of a 3320 or 3520 and I am selling my 4110 with smaller deck. This time I want every thing final, Hope this is my last tractor. went from a 455 to 4110 now a 20 sir.
thanks
roger
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #6
I looked the up the specs on the 3320. Wheelbase is 68" (center of front wheel to center of rear wheel). I went to the manual for the tractor to get width (rear tires). Widest tires would give a max width of 59", min width of 53.9. Should be a good setup with the 72" mower. Here is a direct link to manual. Click Here
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #7
I have a 3520 coming anyday. I ordered the 72" 7-IRON MMM.
The 'build a 3520' configurator does allow the use of the 72" deck.
Cheers,
ldm
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #8
If you want to see it check out the link in my sig. I own the 72" 7-irom MMM on my 3320. I love it. I mow at least 3 acres weekly with mine. I did remove it this winter. Very soon it will be going back on I guess - Spring is right around the corner.
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #9
looks like the same setup I have on mine (just got it). How much trouble really is it to remove and put on the MMM when you want? I know the loader is the slickest thing I've seem yet.
   / 60" 7 iron deck on a 68" wide 3320 series tractor? #10
Pretty easy to remove the MMM really. Remove one wheel for the MMM, drop all the linkage, disconnect some clips, turn the wheels, disconnect the PTO, remove some linkage, and side it out. Manual shows it all step by step.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
