6 Ply ag tires verses 8 Ply ag tires ?
   / 6 Ply ag tires verses 8 Ply ag tires ? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Just bought a new 2012 kioti cab tractor with ag tires.I have a few questions,I burn wood pellets for winter heat each pallet weighs 2,000 lbs.Plus the 400lbs weight of the pallet forks.I noticed today while moving around a 2,000 lbs with my new ag tires that they were pretty much mushed down close to the rim with 30 lbs of air in each front tire.From what I have read the stock front ag tires are 6 ply is this true?Would buying new 8 ply correct this issue as far as side wall flex?Thanks,coobie
   / 6 Ply ag tires verses 8 Ply ag tires ? #2
I guess 8 ply would let you run more pressure. But did you have a heavy weight on the 3pth? Without one, you are essentially doubling the load in the bucket, onto the front tires.
For a few pallets a year I'd put a bit more air in and just go slow with a big counterweight.
   / 6 Ply ag tires verses 8 Ply ag tires ? #3
More 'plys' mean you can add more air to handle heavier loads.. At 30psi, they would crush the same. Add more air when you move heavy stuff..
Yes I did 1,000 lbs of ballast rear weight.coobie
   / 6 Ply ag tires verses 8 Ply ag tires ? #5
Does anyone know how much, if any, that foam filling does for load bearing?
   / 6 Ply ag tires verses 8 Ply ag tires ? #6
Overpressure on a tire and rim in good shape is safe to near twice rated pressure on a temporary basis. Damage and failure is more likely when the tire does not hold its stance under load.
larry
   / 6 Ply ag tires verses 8 Ply ag tires ? #7
Titan® Tire catalog
Titan® Tire catalog
TITAN HI-TRACTION LUG R-1 in 6 ply are rated at 1360 lbs. @ 28 psi. The same tire in 10 ply is rated for 1870 lbs. @ 48 psi. A pair of ten ply tires at 48 psi are rated to carry an extra 1020 lbs. on the front end. I would think that running the higher ply tire would be a good option if you are routinely moving heavy objects with your FEL.
I think that foam filling may be listed as a don't in the tractor manual.
   / 6 Ply ag tires verses 8 Ply ag tires ? #8
Its all about the PSI.. Air supports the load
   / 6 Ply ag tires verses 8 Ply ag tires ? #10
Air pressure is PART of the equation, not all of it. Load rating of the tire carcass is the other element. Load rating is directly related to the ply rating (or ** rating for radials) and tire construction.
2022 John Deere 8R 340 Row Crop Tractor (A44789)
2022 John Deere 8R...
YANMAR SV08-1B MINI EXCAVATOR (A45333)
YANMAR SV08-1B...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2017 INTERNATIONAL...
AGT QK16R Mini Excavator (A44501)
AGT QK16R Mini...
Wacker RT Walk behind Trench Compactor (A44391)
Wacker RT Walk...
2002 Case 221D Wheel Loader (A42021)
2002 Case 221D...
