6 lug Case 530 rim interchange???
   / 6 lug Case 530 rim interchange??? #1
Dwragon
Case 530 Oliver 770, jd 400 bh
Hello everyone, I have a loader that is supposed to be a Case 530, the rims are shot, and I am trying to find another set to replace them with, but everything I have seen is 8 lug. The rims on it do not have the separatable center.the tire size is 19.5-24. Does anyone know an interchange, or how this oddity came to be?
   / 6 lug Case 530 rim interchange??? #2
I wish you luck.
If love to find a set of 6-lug 16.5 rims so I can put 12-16.5 R4s on the front of my tractor.
Seems Kubota was the only one that is of that. Why they couldn't just go 8-lug like all the skidloaders is beyond me
   / 6 lug Case 530 rim interchange??? #3
A JD4310 single piece wheel is that size. Takes a 43x16-20 R4 LVA12001. A 3038e wheel will fit, too.
   / 6 lug Case 530 rim interchange??? #4
I wish you luck.
LD unless I'm mistaken the MX6000 R4 front tire option is a 12-16.5 tire on a 6 lug rim.
Unverfurth in Kalida, Ohio may have that rim as a stock item, they surely will build a pair to your specs. You would have to go through a dealer though. When I was up in NY they built 3 or 4 custom wheel configurations for the dealership that were either obsolete from New Holland or just stupid expensive.
   / 6 lug Case 530 rim interchange??? #5
What part of the rim is shot? If your centers are good just weld them into new 24" rims. Just about any farm tire dealer should be able to get you rims without centers.
   / 6 lug Case 530 rim interchange??? #6
Wasn't wanting to break the bank.
I could order rims from my local dealer.
Skidloaders are hugely popular around here. As are guys always on marketplace and clist selling tires and rims used. And half wore out I see about $100 per wheel and tire.
Not sure but I haven't found any skidloaders have a 6-lug that has the 12-16.5s.
   / 6 lug Case 530 rim interchange??? #7
Yeah, I haven't seen that either.
I'd still check with Unverfurth. They make a lot of OEM rims, some for applications we aren't aware of. Finding used won't be easy.
   / 6 lug Case 530 rim interchange??? #8
That why I said it would have been real nice if Kubota just used the standard 8-lug skidloader bolt pattern. Instead of reinventing the wheel (pun intended)
   / 6 lug Case 530 rim interchange??? #9
Then there would be all manner of crying about oddball R1 and R3 rims. Unintended consequences. Bottom line; the application doesn't warrant 8 lug wheels.
   / 6 lug Case 530 rim interchange??? #10
I guess I hadnt really thought about that and 8-lug 16" rims to put ags up there wouldnt be too common.
One of these days I'll just get a set of 8-lug skidloader rims and turn them into 6-lub rims or make some adapters or something.
Its not too high on my priority list....more like on my wish list to have the heavier and wider R4's up there
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2010 International 4300 2,000 Gallon Water Truck (A49461)
2010 International...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
