6 bolt Turf Tires
   / 6 bolt Turf Tires #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
Anyone know where I can find some 6 bolt rims and turf tires for my Yanmar in 25 X 8.5 X 14 (fronts) and 13.6 X 16 (Rears)
   / 6 bolt Turf Tires #2
I know that the 770 & 970 use those sizes. I think that the 750 may have also. No idea if the patterns are correct. I've re-drilled rims (kubota ? to deere 750) to fit before and i did a post on it, but I don't remember which section I put it in. It wasn't that bad, so if you can't find a pattern match, I would buy the best deal I could find and re-drill them.
   / 6 bolt Turf Tires #3
Assuming you can not source them from a Yanmar dealer...
Perhaps check with John Deere. I think this was the same tire size my old JD 750 4x4 used on front and back and I'm fairly certain they were six bolt wheels. (Concure with Villengineer)
My neighbors B9200 Kubota uses the same size in the rear, but I'm uncertain about the front. He has a new front and rear rim that has not been mounted yet that I might be able to measure if needed. I will not be able to do so for a couple of days though.
   / 6 bolt Turf Tires #7
We have a set of wheels and turf tires off of a 750. I can measure the bolt patterns if you want.
   / 6 bolt Turf Tires
that would be great...and if you have some pictures...even better!
John Deere M Tractor (AS IS) (A50774)
John Deere M...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
John Deere 652R (A50121)
John Deere 652R...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
