5w30 instead of 10w30 in Isuzu Diesel water cooled engine?
   / 5w30 instead of 10w30 in Isuzu Diesel water cooled engine? #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
Hi,
I'm pretty sure it should be fine, right? The owners manual I have for my Iseki is from the 80s or 90s and states to use 10w30 oil for all season use. 5w30 for diesels is actually cheaper over here, and more available. Capacity is 6 liters. If anything, it should start better in winter, right? (Though in temperatures a bit below freezing last winter it started fine, and seems the guy who sold it to me put 15w40 in it, as that's sort of "standard" for tractors and cheap :-/ )
   / 5w30 instead of 10w30 in Isuzu Diesel water cooled engine? #2
Your assumptions are correct. 5w30 will be fine.
   / 5w30 instead of 10w30 in Isuzu Diesel water cooled engine? #3
I agree. As long as the oil meets (or exceeds) your engine manufacturerers requirements it will be even better for your engine than the 10W30 for the reason you already stated.
DEWFPO
   / 5w30 instead of 10w30 in Isuzu Diesel water cooled engine? #4
I run 15W40 - what Kubota recommends. Works just fine and starts great - even in the winter.
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
