5ft or 6ft Bushog.
   / 5ft or 6ft Bushog. #1
BudDawg
N. MS
I am going to get a Branson 4520 and need a bushhog. The 6ft looks awfully big. Over time will the heavier 6ft wear out the PTO and lift quicker than a 5ft or am I just clueless a newbie.
   / 5ft or 6ft Bushog. #2
BudDawg, I have a 3520 and use a 6 footer for field mowing and minor brush control with no problems. If I had a 4520, I would get either a really heavy duty 6 footer or a medium duty 7 footer.
A 5 footer is too narrow and won't cover your track.
Don't worry about the PTO or the 3 point hitch. They are built for this sort of work.
   / 5ft or 6ft Bushog. #3
I agree. A five foot brush hog won't be as wide a your tractor and you'll end up with a lot of grass that will be mashed under you wheels and won't get mowed. I have a Century 3040 and have had no problems with a 6' mower. I would look carefully at different manufactures and pay a little more for a beefier gear box.
Was looking at the SQ720 Bush Hog, 10 guage thickness with slip clutch.
   / 5ft or 6ft Bushog. #5
BudDawg,
The SQ720 is classified as a Light Duty cutter by Bush Hog, and it weighs 632 pounds. Your tractor has a rated lifting force of 2580 pounds at the lower links. I don't think you need to worry about overloading your 4520 with that cutter. /forums/images/graemlins/smile.gif
Your tractor could handle a light duty 7' or a medium duty 6' if you want to spend the extra money for the wider cut or heavier construction.
   / 5ft or 6ft Bushog. #6
Have you asked the dealer for a quote on a Branson cutter? They are built by Kodiak and are decent units. Implements are usually deeply discounted when they are purchased as part of a package.
   / 5ft or 6ft Bushog. #7
</font><font color="blue" class="small">( BudDawg, I have a 3520 and use a 6 footer for field mowing and minor brush control with no problems. If I had a 4520, I would get either a really heavy duty 6 footer or a medium duty 7 footer.
Don't worry about the PTO or the 3 point hitch. They are built for this sort of work. )</font>
Right on
   / 5ft or 6ft Bushog. #8
BudDawg,
I'm guessing that the 4520 is 45 h.p. I have a 45 h.p. Century that handles my 6' mower with no problem at all.
2018 Ford F-150 (A51039)
2018 Ford F-150...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
RoGator 844 sprayer (A50490)
RoGator 844...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
