Mowing 5ft or 6 ft finish mower for jm224
   / 5ft or 6 ft finish mower for jm224 #1
jaroban
TX
Kioti dk40se
I am going to mow three acres of flat land bermuda. Should I get a 5' or 6' finish mower? I have a new 22hp jinma tractor.
Robby
   / 5ft or 6 ft finish mower for jm224 #2
I would recommend the 5'. My personal opinion the five would be the best fit for a 22 hp. tractor, overall with high, thick, or wet grass, and cutting 'quality'. It is easier to keep your rpms up with the smaller one, also check the weight and make sure your tractor 3 pt. is capable of lifting the wieght of the mower. Good luck!
   / 5ft or 6 ft finish mower for jm224 #3
I vote for the five footer
//greg//
   / 5ft or 6 ft finish mower for jm224 #4
Since you are talking finish mower, I would have to say 5' max. You need to keep your rpm high enough to keep up the PTO speed. If you don't keep the blades turning fast enough you will not get a nice even clean cut.
If we were talking a shredding/rough cut/deck where looks were not the object of the mower, I would still have to say 5', bermuda can be a very thick, heavy mow during certain times of the year in Texas, even running blades of Costal Bermuda can slow down a good cutter.
KENMORE ELITE REFRIGERATOR/FREEZER COMBO (A51248)
KENMORE ELITE...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2004 Ford F-550 Wrecker Truck (A51692)
2004 Ford F-550...
Ditch Witch R 40 (A52384)
Ditch Witch R 40...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
