580k torque converter
   / 580k torque converter #1
sport20
hi
i'm new to this site so hello to eveyone. i bought a case 580k which has 9000 hrs on it. i started doing some much needed maintenance. changed trans/hydraulic cooler in front,replaced all seals on 4 hydraulic cylinders.
i took out bottom drain plug on torque converter housing and quite a bit of oil came out. i don't think there is supposed to be oil in the housing. do anyone know what might be leaking. it is a phase 3. any help would be appreciated
thanks in advance
   / 580k torque converter #2
Welcome to TBN. Is the phase 3 the type were the transmission is separate from the torque converter? Did you check the oil level before that oil came out? Off the top of my head I would think that a seal on the torque converter, it could have been over years and the level just topped off as needed or it could be more of a problem. I assume it runs and drives fine, if so I would keep an eye on the oil level and if you don't mind topping it off and maybe a leak or two it could give you years of trouble. I don't know if you can just replace the seal(s) or not. I think if you have to replace the torque converter it's pretty pricey.
1990 UNKNOWN 16 T/A TRASH TRAILER (A53843)
1990 UNKNOWN 16...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
FAKE (A52472)
FAKE (A52472)
