SCISSORMAN
Help! I need someplace to get the o-rings, seals, for the loader lift spool. I have the part#'s, the problem is someone has had this control valve apart in the past, and the most important seal-#A16877- WAS REPLACED WITH AN INCORRECT o-ring. This makes the spool slightly out of position, making the hydralic pump , pump against a partially closed valve. I need new orings and seals for on this spool, the correct ones. Pretty much case says nothing available for this valve. Even if someone could give me some measurements of that seal, I could get something close that may work at my local hydralic supplier. Thanks!
Randy
Randy
