580CK 1967 Shuttle Problem
   / 580CK 1967 Shuttle Problem #1
Higherground
California, Ontario
Case 580ck
I am having trouble putting the tractor into forward. I put the clutch in and push up on the shuttle lever, when I release the clutch it just grinds. If I continue every 10 or so times I do it, it will go into gear and move forward. This is very frustrating. Last year I had to replace the shuttle rail. It snapped in two. It was starting to give me some trouble before it snapped. Here is a picture of the rail I replaced.
Any help would be great.
   / 580CK 1967 Shuttle Problem #2
I am more familiar with the shuttles in Kubotas, but their clutch pedal linkages go to a pressure dump valve on top of the transmission. The hydraulic pump jn the transmission pressurizes the synchro plates and makes forward or reverse accordingly. When you press the clutch it is supposed to dump the pressure instantly releasing the synchro from the engine so you can change gears without grinding or not going at all. I would check the flow valve that dumps the oil. It sounds like that isnt releasing the pressure; like a burr on a spring detent or something hanging up internally in the valve.
Anyway hope i didnt confuse you and i hope this helps. Let me know if i can spread some more light
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
2016 Ford F550 Flat Bed (A52377)
2016 Ford F550...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
24in Tractor Backhoe Bucket BT4555 (A53472)
24in Tractor...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
