Backhoe 580B Case With a Fuel Leak
   / 580B Case With a Fuel Leak #1
Andover
Guelph Ont. Canada
JD8225R JD7810 JD 7410 JD 4010 JD 4020 Ford 9030 Case 580B SpraCoupe 4655
I am new to your site.
Thanks for any help.
I have a 580 B Case Backhoe with a factory cab that has a fuel leak in the tank. Drips on the floor of the cab!!! (The tank is located under the windshield.)
Wondering if anyone has removed a tank from one of these machines????
Do I have to lift the cab???
Doesn't look like fun, but looking for some direction.
   / 580B Case With a Fuel Leak #2
The 580B I used to play with was open station, so I'm afraid I don't have an answer for you, but welcome to TBN. I'm sure someone will be along with an answer soon.
40' High Cube Multi Door Shipping Container (A53316)
40' High Cube...
Pallet Of Mini Excavator Attachments (A47477)
Pallet Of Mini...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
Farmall Cub Tractor w/Attachments (NOT RUNNING) (A50775)
Farmall Cub...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
