57 FORD 850
   / 57 FORD 850 #1
OLDFORDS
FORD 850
MY 850 IS SHUTTING DOWN WHEN COIL GETS HOT, AFTER COOLING DOWN IT WILL START,, BUT WHEN PULLING HARD WILL CUT OUT. ANY HELP WOULDD BE APPRECIATED ! THANKS
   / 57 FORD 850 #2
Probably a faulty coil, ignition switch, or poor harness connection. When it cuts out, don't touch the ignition switch but immediately use a meter or test lamp to check for power at the coil connection coming from the key switch. If power is present, replace coil. if not, tract the circuit back to the fault.
   / 57 FORD 850 #3
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
NEW Fork Extensions (A53002)
NEW Fork...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
