555E brakes
   / 555E brakes #1
bikernut
New Hampshire
bikernutgoofy@gmail.com
got a 555E TBL that is leaking brake fluid some where. had myself and another under the machine looking for said leak but couldn't even find the lines looked for about 45 minutes before throwing in the towel. when I fill the reservoir and give it one pump the brakes work wonderful and like the old Mercury ad says stops on a dime, wait a day or two and then reservoir is empty again. put fluid back in it and you can see it self bleeding and good brakes again. it has to be going some place but we couldn't as I said even find the lines or any excess fluid other the a hydraulic leak on one of the valves by the hydraulic reservoir tank. parts book show 2 lines to rear differential but I can't find said lines with the flexible hoses connected to them. No fluid under the fill tank and don't see any in engine compartment from master cylinders matter of fact couldn't even find the master cylinders, where are they located? any and all help would be greatly appreciated. thanks
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
