555e backhoe
   / 555e backhoe #1
Blackhawkranch
New Holland 555E
I have a NH 555E backhoe. I have ordered a Hydraulic pump (twice) and the wrong pump is sent both times. The original pump has been superseded with a new part number but the new pump that was sent is nowhere near the original. Has anyone else run into this?
   / 555e backhoe #2
I hope to never need a pump.
Where are you ordering from? Bruce at Alma tractor is pretty knowledgeable.
   / 555e backhoe
I have ordered from 2 different places. AMS Construction Equipment and Messick. Both pumps were the same. The New Holland site says the pump should weight around 44 lbs. The pump I received is around 70 lbs. I will talk to Messick tomorrow to see if I can get this straightened out.
   / 555e backhoe #4
I am certain that Messick's will get the answer for you.
They are the most helpful tractor folks anywhere.
   / 555e backhoe #5
I have a 1998 555E and haven't had to buy a new pump yet. I have had very good luck ordering from Messicks from their online parts diagrams. I waiting on some gaskets from them that should arrive today.
My New Holland Dealer, George Baine in Tyler TX, has been very good at providing me advice and alternative sources for parts and repairs. It's almost like they don't want to do the work there. Their rebuild kits for hydraulic cylinders went crazy after Fiat bought out Case and New Holland. They added more and more seals to the kits and then made you buy a new piston. What used to cost $40 in parts went up to $100 or more, plus another hundred bucks for the piston. They told me where they have their cylinders rebuilt, and the guy buys just the seals needed, plus $100 labor to do all the work. Seals are usually $5
When one of my hydraulic pumps went out on my Case dozer, the dealer said that they do not rebuild them, or work on them, they will only replace the pump with a new one, which costs $25,000 for the pump. I found a hydraulic rebuild shop in Lone Star TX that rebuilt it for $3,000. I had to remove the pump from the dozer and bring it to them, then install it after they where done. It was a pain, but well worth the cost savings!!!
40' CONTAINER (A51244)
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
