AlanB
Elite Member
Probably not the proper terminology but close enough. My Backhoe has developed the nasty habit if the transmission "disengaging" at the most inopportune moments. I will be doing something, and it just feels like I kicked the forward reverse stick into neutral. I will move it back and forth, try different gears, etc. etc. and at some point, of its own volition it will decide it wants to work again. I have not narrowed it down to a particular action I am doing to cause it, it just seems random. And it seems just as random as to when it resumes operation.
I have checked all the fluids and they look ok, but they do need to be changed, so I am thinking that may be a logical easy troubleshooting step to insure that the fluids are not the problem
I do have the manual, and have not read through the troubleshooting procedures, but guessing it starts out with some high dollar super pressure gauge with a fitting made from unobtanium unless you are a listed ford backhoe dealer so was hoping maybe someone here had stumbled into a similar situation before and could lend some insight.
