555b ford
   / 555b ford #1
john davison
555b ford
1988 555b trans will not engage drained fluid , fluid milky, refilled, checked filter fluid still milky but not on dipstick,trans engages intermittently,any suggestions appr.
   / 555b ford #2
Oil floats on water.That may be why the dipstick is showing oil on it.
I know it costs more $$ to change it again but you should do it at least one more time.Use the cheap trans. fluid first then what you prefer.
Hope it helps.
   / 555b ford #3
I don't know what 'checked filter' means. Under the circumstances you should change the fluid and filter at least once more. Some of the oil in the system is trapped in the torque converter and is impossible to drain. Oil and Filter is cheaper than clutchpacks and transmission pump.
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2014 Triple Crown 10ft S/A Utility Trailer (A51694)
2014 Triple Crown...
2024 Rhino 4155 Batwing Mower (A53473)
2024 Rhino 4155...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2004 Honda Accord Sedan (A51694)
2004 Honda Accord...
2013 Ford Explorer AWD SUV (A51694)
2013 Ford Explorer...
