553 FEL very powerful and versatile
   / 553 FEL very powerful and versatile #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
I have a 5065e with 9/3 TSS Sync shuttle transmission and MFWD with filled rear tires. It has the 553 loader with HD bucket. I am fairly new (4 years) to tractors and use mine to maintain an 80 acre farm with timber, food plots and road maintenance. I continue to be impressed at the power of the FEL. I use it for brush clearing including pushing over small trees. This weekend I was pushing over 2-3" diameter Sweet Gum trees at a time including root balls. In low range and 4WD it is a very powerful tractor. I have hauled buckets of gravel, about 1500 lbs per trip filling ruts in logging roads. I have moved large stumps that were excavated with a TRAC-hoe. I find in pushing large piles of brush curling and dumping the bucket while pushing forward is a technique that helps keep moving if Traction is a problem. I also keep it close to ground when bush-hogging to knock over small trees before going over the with my Bush Hog 296 cutter. In summary, I am very glad I got the FEL. I can't imagine not having it and continue to be amazed at its power. If I sound like a rookie, sorry. This is my first tractor and I am very impressed.
   / 553 FEL very powerful and versatile #2
Sounds like you are having a great time. :thumbsup:
When you get around to adding forks to that FEL, you will discover a whole new dance time.. if like me, the forks are on for more than half the different jobs around the timber farm here.
But no rush.. enjoy!
Sounds good. I have been really wanting a grapple too but they seem pretty expensive. I have 1 unused remote valve on the back of machine. It seems like the loader options are numerous.
   / 553 FEL very powerful and versatile #4
If you are impressed at what you can do with the FEL, and it is a lot, you aren't going to be fit to live with if you get a grapple. :D
Yea, I think you are right. Been watching u-tubes and they look awesome.
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
