'55 Oliver Super 55
   / '55 Oliver Super 55 #1
Mitsubishi MT2001D
I bought the Oliver a new battery yesterday (he's been busy playing paperweight too long) and mowed all afternoon. Mowing in thick, tall weeds. He got hot (I've cleaned off the radiator!!), but I checked a couple hours later when I fed the livestock. Started right up, not a bit of lag.
I have replaced the battery clamps, all is tight, and the cables look to be good.
Tractor has been here three years with an ancient battery and always started first crank.
Until he didn't.
No lights on this beastie ... next idea?
Thank you!! :)
   / '55 Oliver Super 55 #2
The battery clamps are good....clean? How about the battery ground where it atraches to the frame? Tight, clean?
   / '55 Oliver Super 55 #3
Check the battery voltage. A twelve volt battery fully charged should settle at about 12.6 volts. A six volt battery should hit about 6.3. What happens to the voltage when you turn on the key? Check the voltage at the fuse block or ignition switch with the key off and then on.
2023 54ft Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54ft Hooklift...
2025 Victor X-Pro Mini Dirt Bike (A55758)
2025 Victor X-Pro...
2011 Ford Edge AWD SUV (A55758)
2011 Ford Edge AWD...
1983 Case 580D (A47477)
1983 Case 580D...
Golf Cart (A55853)
Golf Cart (A55853)
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
