54D mide deck mower belt change
   / 54D mide deck mower belt change #1
FishHaggis
John Deere 2320
I broke the belt and just got the new one. I snaked it all into the right position but can not get that tensor pulley spring back on as the belt is just a bit too tight. I am sure once I get it on and work it a bit, it will loosen up, but I just can't get that spring back on.
Any suggestions?
   / 54D mide deck mower belt change #2
The spring came off of mine while in use. I had to use a pair of vise grips to clamp down on the spring and pull with all my might.
I have a brake drum tool that probably would have worked also. The springs on brake drums are just as tough to put on.
   / 54D mide deck mower belt change #3
I think I've used these for a hose - once. I've used them to take off and put on a bazillion springs - they are great for that! :thumbsup:
3 Piece Long Reach Hose Grip Pliers
I find they get into tighter spots and are generally more versatile than brake spring pliers.
Well I used a ratchet strap on the pulley lever and then muscle and a pair of pliers for the spring and presto, I got to mow my lawn......
I will keep an eye out for those pliers and brake spring gizmo next time I am at TSC...... Thanks for the help!!!:thumbsup:
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
Concrete pump (A52377)
