54C Stuck in Locked Postion on X585
   / 54C Stuck in Locked Postion on X585 #1
JJE64
X585
After using my 3pt yesterday thedeck is now stuck in the locked postion on my X585. I cannot turn the knob at all. I have raised and lowered the 3pt in an attempt to free up the knob.
Any ideas? Has anyone else seen this? Is something bent or broken in the mechanism?
jje64
   / 54C Stuck in Locked Postion on X585 #2
jje64,
Try raising the 3PH control all the way up and then turning the control knob. I have had this issue on both my 425 and 2210 (when they were newer) and got it unstuck this way. There is, of course, the possibility of something being bent or out of adjustment, but I would try that first. /forums/images/graemlins/tongue.gif
   / 54C Stuck in Locked Postion on X585 #3
The same thing happened on my 62c deck. All I did to free it was, pick the deck up and down a couple of times by hand on one side and it free it self. My knob wouldn't turn either so it the same problem that I had. Only happen once, it's not an on going problem.
2210 - 200CX 53" FEL, 62c MMM, 47" Two Stage Snow Blower, 48" Tiller, PHD, I-match Hitch, ballast, and PTO driven TRAC VAC
   / 54C Stuck in Locked Postion on X585 #4
Ditto. Had it happen a couple times. Grabbed the left side of the deck and shook it whilst turning the knob.
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
