Snow 54 inch Snowblower
   / 54 inch Snowblower #1
Kamik
Bronze Member
Maine
John Deere 2520
My 54 inch quick attach snowblower just crapped out for the third time - a piece of frozen snow from the plow bank passed thru the auger and snagged the fan, causing the fan drive train to strip out. For some reason the shear bolt never breaks. The last repair cost 1200+ dollars and I have no appetite for paying it again.
Has anyone else experienced this problem, with either the 54 inch or 47 inch snowblowers? Is the 54 inch design just a POS?
I have a 2520 CUT. What are the realistic down-sides of getting a 47 inch blower to replace the 54 inch?
Are there alternatives to a snowblower that I should consider, that might work better or more reliably, e.g. a third-party plow or loader attached plow?
Your feedback is greatly appreciated!
K
   / 54 inch Snowblower #2
Wow. I would make sure the shear pin is the right one. Take it out and see if it works like it is supposed to. Stay away from ice chunks or at least big ones. They are hard to see I know, but hit the banks before everything turns to ice.
I had a 47" on a X740 and its predecessors and it was a nice blower. But the biggest noisy chunks I hit were maybe softball size, and it was noisy as all get out. It broke a few shear pins like it was supposed to.
I don't think a smaller blower is the answer.
   / 54 inch Snowblower #3
Softer shear bolts are the answer,but you would grow tired of replacing those.you need someone to tell you what model has the heavy auger and fan ,but with a reduced width. Any one with the facts?
   / 54 inch Snowblower #4
Kamik what are you referring to when you say the fan drive train "stripped out"?
the fan is attached to a shaft with key and setscrews, that shaft is driven on the back
side of the blower by chain and sprockets, which are driven by the front pto kit
on the tractor.
   / 54 inch Snowblower #5
I was kind of questioning the same thing as Dutch. I have shear a few bolts on my fan without doing any damage. Grade 5 is what I'm using on my 47'' blower. When you damage it were you operating your blower at 540 pto rpm?
   / 54 inch Snowblower #6
The front-mount 54" blower runs off the mid-PTO which is 2100 RPM. If in doubt about the shear bolts I would recommend stopping by a local JD dealer and buying some factory replacements. They are very inexpensive. In addition, the 54-inch blower shipped from the factor with some spare shear bolts stored near the exit chute.
   / 54 inch Snowblower #7
Thanks for clearing this up jgayman. I assume that everyone knew what I met when I said ''operating at 540 pto rpm''. :)
   / 54 inch Snowblower #8
Does his 54 have the plastic fan? Is it possible to change it to the steel fan? Someone has them on ebay for $275.00
My 47 has digested some pretty large chunks of ice and possibly some frozen vermin as well and I've never sheared a fan bolt but have a couple of auger bolts when it tried to eat a rubber hockey mat. I do find that the shear bolts loosen up over time and need to be re-tightened
   / 54 inch Snowblower #9
I also use blue lock tight when I replace a shear bolt and lock nut. They last a lot longer this way.
   / 54 inch Snowblower #10
When it comes to shear bolts, soft metal (like box store stock) will stretch and cause elongation B4 shearing,
Grade 5 bolts, while harder, will shear clean when the limit is reached.
You want the holes that the shear bolt fits to be like a shear (sharp edges) to be effective.
Never torque up tight, just snug but always use a lock nut.
I used from time to time soft hardware bolts and they simply messed up my cutting edges.
Ever since I went to grade 5 my troubles went away.
So far this winter I am on the same shear bolt that I installed last mid winter.
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2023 Kubota SVL97-2 (A50120)
2023 Kubota...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
