5325N vs. 5425N Engine questions
   / 5325N vs. 5425N Engine questions #1
patmajia
Anyone know much about that 3.0L 5 cylinder in the 5325 vs. the
4 cylinder 4.5L in the 5425? Durability? Reliability? Too early to tell?
   / 5325N vs. 5425N Engine questions #2
I've been wondering the same thing. While only 10 more hp the 4-cyl has a 50% increase in displacement and 28 lb-ft more torque. The 4 cyl seems more similar to the engine used in the next larger frame tractors. The 4-cyl has wet sleeves while the 5-cyl does not. The 5-cyl seems to use a lot less fuel, like 1 gph less.
The local dealer has several 5325's in stock but no 5425's.
I can't be of much help since I've been asking myself the same questions, and if the 5325 can do the job for me. The engine choice has no efect on the wheelbase, they seem to fit in the same chassis design.
Intuitively it would seem 50% more displacement should offer a lot more power, but as far as reliability maybe it is too soon to tell.
   / 5325N vs. 5425N Engine questions #3
The 276 engine has been around since 1998 with or without a turbo.
The turbo was first used on the 276 on the 5510 in 1998 through 2000. This was continued on the 5520 in 2000 and the 5525 in 2005.
The 276 was used without a turbo in the 5410 in 1998 and in the 5420 in 2000 until 2005 when it was given a turbo for the 5425 series.
The 186 engine was introduced in 2005 for the 5225 and 5325.
   / 5325N vs. 5425N Engine questions #4
We have a 5420, 276 non turbo. It is pretty much old school design, but a very durable diesel. It is quite noisy but powerful. So far, so good but only about 380 hours. I love it.
Under heavy PTO load, (heavy brush hogging) it burns about 2 gallons per hour.
   / 5325N vs. 5425N Engine questions #5
The local Deere dealer has had some problems with the 5 cylinder engines. They use electronically controlled injectors that are in the valve cover. Probably more efficient than the mechanical injectors but more expensive and trouble prone. The service manager said one tractor had problems with the injection system and the other was smoking badly and the engine was replaced, it was a new tractor. The 276 engine in the 5425 goes back to about 73 or 74 I think. It was first used in the 2630 tractors. It is in the 2640 that I have, it is a 78 model. It has had some changes over the years but I think it is still basically the same engine. I think that I would rather trust the 5425 myself.
   / 5325N vs. 5425N Engine questions #6
"The 276 engine in the 5425 goes back to about 73 or 74 I think. It was first used in the 2630 tractors. It is in the 2640 that I have, it is a 78 model. It has had some changes over the years but I think it is still basically the same engine."
I missed that when I was looking up information on the 276 engine.:eek: :eek:
   / 5325N vs. 5425N Engine questions #7
My local JD dealer has had issues with the injectors as well, his observation was to use only "fresh" diesel, purchased as needed, not in bulk and stored for any length of time (like a season's use).
   / 5325N vs. 5425N Engine questions #8
I own a 5425, plenty of power. Run it mostly on the lower RPM PTO setting, even when mowing. Have about 150 hrs on it, with absolutely no problems. I have been very pleased with the performance, and reliability. Use it with brush hog to mow approx 70 acres, spraying, loader, blade, etc. Even use it in the winter to plow snow, and it starts easily. Also easy to service, everything is very accessible.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
