5303 Seat Sensor
/ 5303 Seat Sensor #1
deere5105
Veteran Member
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I recently upgraded to a 2008 JD 5303 MFWD. When running JD MX6 cutter I kept hearing a noise like an alarm going off. With the engine running at top speed I couldn't make out where it was coming from. There was no noticeable change in anything, just the noise. I noticed it was happening typically when I would engage the brakes and/or clutch. I narrowed it down to being the seat/PTO sensor causing the alarm. I throttled the engine down with PTO engaged and could stand up and make the alarm go off. Since this sensor appears to be a little sensitive and doesn't appear to cause the PTO to disengage, I am interested in bypassing it. My previous tractor had it bypassed from previous owner. I fully realize the dangers of a PTO running while being out of the seat. I have not had a chance to look it over lately, but is anyone familiar with a simple procedure for this?
/ 5303 Seat Sensor #2
use a jumper wire in the plug on the harness, then tape it up
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
