530 Hydraulics
/ 530 Hydraulics #1
farmerwantab
PA
Case 530 loader
Hi, I'm a new member and I had a question, I'm trying to hook up a woods backhoe to a Case 530 Loader only with a 3 point hitch and I'm not sure where to hook the hydralic lines to. It had two remote fittings at the rear that the manual says were for a cylinder, I hooked up to them but when I pull back on the rh. outer handle to operate it, it puts a load on the motor. I think maybe I have to rout a return line into someware else, not sure. I have pics if needed. Any help would greatly be appericated.
Thanks, GMT
/ 530 Hydraulics #2
If you can get fluid to the BH, then you can run the BH return to the filler cap, or a return hose.
Recheck your QD's.
/ 530 Hydraulics
Thanks JJ, both QD's, male, female and hoses are brand new. The book says the outer lever forward pressurizes the top fitting and back the bottom, so i did just that, ran one from the top and ran the other to the tee at the filter as a return and that didn't seem to work either. The hoses come from an aux. valve in front of the steering wheel panel and I didn't know if that was a seperate circut or not.
GMT
2006 Ford F-250 Knapheide Service Truck with Liftgate (A64556)
2006 Ford F-250...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
UNUSED FUTURE BC72-72" HYD BLOCK CRUSHER (A65055)
UNUSED FUTURE...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
