5254 Lubrication of drive shafts
   / 5254 Lubrication of drive shafts #1
wojnaroski
East Tennessee
Kubota bx1870
I have greased my 5254 drive shafts, both main and 4wd shafts twice.
What a treat! Found a total of 5 zerk fittings on these shafts. Almost impossible to get at. Probably fat hands or something. Anyone else have any thoughts on this or easy techniques they wish to share?
Still a great tractor.
   / 5254 Lubrication of drive shafts #2
If I remember correctly the rear u-joint on the main shaft is the worst to get to. I had my wife bump the starter while I laid underneath to get the grease fitting aimed in the right direction. Not anything you can accomplish with the deck on!!
While I was laying under my tractor today, a thought occured to me. It seems that the foot rest is attached with only a couple of screws and bolts. Could you not remove the foot rest and have unfettered access to both drive shafts on the transmission end?
I also found that if you remove either of the side engine covers you can very easily reach the fly wheel end of the drive shaft for lubrication.
   / 5254 Lubrication of drive shafts #5
My dealer installed a 90* elbow zerk. Makes greasing a bit easier.
Good idea. Wonder if Cub Tech has any input on this subject? My dealer sure as heck doesn't.
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
