Jesser02Ex
Bronze Member
- Joined
- Aug 10, 2018
- Messages
- 61
- Tractor
- Branson 5220R
Fellow Branson owners,
I have a 5220r with just over 100 hours. Today I was doing some grapple work stacking tree limbs in a burn pile. It was regular work like I致e completed many times previously. What got my attention was when I parked the tractor in the barn.
I noticed I had some fluid under the operators station of the tractor. I looked under the tractor and notice the fluid was clear hydraulic/transmission fluid. I went to the back of the tractor and the sight glass is showing full in the middle of the window.
I did not see where any fluid had been pushed out of the rear vent where you fill fluid. The filter is dry and did not show any leak. The drain plug was tight and not the source, however, the lower area of the transmission, near the drain plug, was wet and dripping.
I wiped everything up, nothing more than an ounce, but this is till a first and I知 ocd about leaks.
Has anyone experienced this or have a suggestion of where I can look for the leak? Does the relief valve on the loader dump any fluid out of the system?
Any feedback or thoughts?
Thanks, Jesse
Thanks, Jesse
