520H only runs on 1/2 choke...
   / 520H only runs on 1/2 choke... #1
monkers
I have a 520H with an Onan engine and had thought the fuel pump was bad earlier in the seasnon, now the engine surges unless you use 1/2 choke, i checked the gov adj like the book says and it was fine, dirty carb? Thanks
   / 520H only runs on 1/2 choke... #2
I would start by cleaning the carb. Sounds like there may be some debris in one of the jets causing it to run lean.
Roy
Thank you
   / 520H only runs on 1/2 choke... #4
I found taking the air filter off for access to the carbeurator and using compressed air to blow out every orifice you can find will clear the carbeurator and it will run fine. be careful you will spray out gasoline, atomizing it, making it highly explosive. I had to do this on two occasions and on two different 520H's and the tractors runs fine now. Beats taking the carbeurator off and cleaning it.
CAT 416B (A47477)
CAT 416B (A47477)
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A52377)
2015 Ford F-350...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
1989 TRAILMOBILE 45X96 SPREAD AXLE FLATBED TRAILER (A53843)
1989 TRAILMOBILE...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
