520 xi overheating
/ 520 xi overheating #1
Wheelhorse Willy
Southeast NY
2004 520XI
Has anyone experienced a situation with a 20 HP Kohler air cooled on a 520 XI where the guage says it is getting to hot but I can't find any obstruction around the engine or oil cooler?
I have blown everything out with high pressure air but the way the engine is installled the back of the engine is inaccessible.
Since Kohler offers a kit for access panels to clean out the rear of the fins I suspect this may have been a design flaw although the back of engine where these panels would go is still inaccessible since it is up against a firewall on the 520XI and installing them and using them would involve hours or disassembly.
The machine runs smooth so I don't think it is running lean... is there a way to check it out before I throw down $70 on a new temperature sensor??
Love the machine and it only has 65 hours... it is a 2004 that I got from a dealer after they were discontinued.
Any input appreciated!
WHW:confused:
/ 520 xi overheating #2
Hi WHW,
I have the Kohler service manual for your engine (I have a 522xi), and for overheating it list the following possibilities:
Air intake/grass screen clogged, cooling fins, or cooling shrouds clogged
Excessive engine load
Low crankcase oil
High crankcase oil
Faulty carburetor
Lean fuel mixture
SMART-SPARK, malfunction (applicable models)
I have not had an overheating problem with my tractor, so I can't point you to anything in particular.
How long does it take before it shows "hot"?
What are you doing when it reads "hot"? Mowing at full rpm?
Did anything change recently, did you change the oil?
Rick
/ 520 xi overheating #3
Leave the air filter assembly in place and use a leaf blower to clear out the dust in the area
around the air cleaner everytime you mow and the entire engine
compartment as this will
solve the issue for you.
Are you using Sea Foam for the fuel? We had our 525 muffler plug up from carbon
and we also had a bad set of coils.
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
